Is Carl about...?
Eddieskidmark
Is Carl about...?
Post by Eddieskidmark »
Will a VFR swing arm fit the VTR...? If so is there a link somewhere...?
Cheers Skids
Re: Is Carl about...?
Search is your friend…. It has been done a few times
http://www.google.co.uk/#newwindow=1&q= ... m&safe=off
Ckennedy
Post by Ckennedy »
Yes it can be done. It's a huge job but it is achievable.
Not cheap or easy ck and I started doing it then he changed his mind AGAIN
Eddieskidmark
Just need to know the options before Maxton makes the shock...!
I put up a thread in the work shop showing shock sizes and the Hagon was the easier one to use
Eddieskidmark
Maxton do all the suspension for my bikes... Got to move battery to get a piggy back in...! And putting cbr 900 forks on it...!
Yeh I'm about :lol: Not sure if there s a thread here or over the pond with a complete how to. Plenty of snippets though. But as others have said it not cheap or easy. I don't know much about it as it's something I have not explored.
Jscobey
Post by Jscobey »
There's 2 highly detailed threads on superhawkforum.com with lots of pictures.
It involves custom linkage brackets and dog bones as well as a custom exhaust as the shock has to be moved and gets in the way of the rear header.
Other than that's its mostly bolt on if you have the rear brake and sprocket. Kinda a PITA to get perfectly on center though.
It's purely for looks and does not offer better performance. Its also a bit longer than the standard arm
Eddieskidmark
Thanks for that.... Sounds like I need to stick with the standard braced one then...lol...lol
Cheers Skids
