red paint code ?
red paint code ?
Hi all, I need the paint code for my 1999 red storm. Took the label off the subframe when it got sprayed and cant find it. Did a google and came up with r-157. If anyone has a red storm or any idea would be great thanks.
- bigtwinthing
Re: red paint code ?
Damon777 wrote:Hi all, I need the paint code for my 1999 red storm. Took the label off the subframe when it got sprayed and cant find it. Did a google and came up with r-157. If anyone has a red storm or any idea would be great thanks.
Yep thats the same as mine.
http://www.vtr1000.org/phpBB3/viewtopic ... 48#p243027
- Squiffythewombat
- Contact:
If you goto halfords they will mix it up for you. Its called milano red and is under the motorcyle section on their machine. Often this is under "motorcicly" or something...werid i know but the machines are foreign. Colour matched several cowls etc. With this. If you dont have an airbrush setup then they can put it in a rattle can for you.
Hope this helps
Hope this helps
Squiffy_The_Wombat
