Battery time again
chric
Battery time again
Post by chric »
Battery time again
seems if you ont charge the mottobat batterys they die if not trickle charged only 14 month old and its dead any suggestions
Re: Battery time again
That applies to any m/c battery - non-use can leave them unable to hold a charge. Whatever you get next do make sure you carry out regular care & maintenance and give it a trickle now every two weeks or so to keep it charged to 100%.
A battery can only be deep-cycled a limited number of times before it is indeed dead.
it may still be worth some tough love to resurrect the old one. I have it on good authority that dropping the battery onto a concrete floor from 1ft or so will act to disulphate the plates, and then put it on a smart charger with a recovery charging program.
worst case you split the casing and have to buy a new one, but other than cleaning up the acid :D , that the same bout you are in now.
chric
Post by chric »
Thanks orderd a 14bs exide going with a known brand this time
bazzashadow
Post by bazzashadow »
my mate said i would need a new battery every year
so i thought i`d try this http://www.maplin.co.uk/p/4w-solar-briefcase-n05hn
if i don`t put this on my storm struggles to start after 2 weeks
but using this it starts first time every time and the battery is know about 3 years old :thumbup: :thumbup: :thumbup:
