cough and splutter
10robbo
cough and splutter
Post by 10robbo »
hello all,i was caught in hell of a storm last week and since then bike has developed a splutter.
considering the age of bike thought I would replace the caps and ht leads.
is it possible to remove the leads form the coils or are they fixed
thanks
Re: cough and splutter
have you cleaned out the tiny drain holes under for the sparkplugs, if not clear they fill up with water during heavy rain and cause the bike to misfire
bazza696
Post by bazza696 »
10robbo wrote:hello all,i was caught in hell of a storm last week and since then bike has developed a splutter.
thanks
It sound like a complete rite off and unsalvageable, if you put it out there someone may give you a good price for her, as long as I get first dibs...;)
plug caps can be unscrewed off the HT lead, I cant remember if the HT lead can be taken out of the coil or if it is epoxied in.
like Marty said, the 1st thing should be to look at the drain for the front sparkplug recess, as if it is blocked it will fill with water and lead to shorting. if you want to change the plug caps and HTs, then you are better off fitting plugtop coils from a newer Honda. there is a thread in the workshop knowledge base on how to do this
See the following post for pics of the front drain hole.
http://www.vtr1000.org/phpBB3/viewtopic ... 60#p352943
Also check the front spark plug and renew the pair if required - as front one can corrode due to water getting in as already mentioned. Get the spark plug recess in the cam cover nice and dry, drain hole cleared and use silicone grease around the rubber cap insert to help repel water.
10robbo
Post by 10robbo »
thanks for your replies,
was not aware of the drain hole,so I will sort that first,then if the leads will come out of the coils I will replace them.
I will as you mention go for stick coils if I can find some sensibly priced
Bananaman
Post by Bananaman »
Hi robbo, stick coils are a mod I've been looking at for a while, if you can only find a set I'd be willing to go halfsies? :thumbup:
Four wheels move the body,
Two wheels move the soul.
The perfect hole-cleaning tool is the little red tube on a can of WD40, by the way.
10robbo
Post by 10robbo »
hi bananaman,
found a set of four from a cbr 600 they are £49.99 posted. if your happy with that ill buy them now so I don't lose them
10robbo
Post by 10robbo »
tony, tried the little tip and it works well.
ps thank god just god for that just got my 50th post
Make sure you also get the wiring loom with the coils
10robbo
Post by 10robbo »
yes did check,loom is included,hope they havnt sold
Bananaman
Post by Bananaman »
Robbo, spot on mate! :thumbup: blimey you don't hang about :lol:
Let me know when you get them and I'll paypal you
10robbo
Post by 10robbo »
bananaman ,
got them bought straight after your post,was sure they would be snapped up.should be able to pm you now when they arrive.
wiring harness is included with them
