Werent doing much this morning so I thought id take the front plug out to see how things were running. When I put the plug socket on I noticed it was loose, removed it, gap was ok and I refitted.
So now I thought id better take the rear plug and check that, removed plug, gapped ok, refitted.
It was the first time id removed the tank and I didn't really check the pipework etc as it looked obvious at the time.
I refitted all four pipes, but when I started up, the bike ran lumpy and coughed and spluttered a bit.
After the engine had warmed up a bit I realised that the engine was running on the front only, I removed the rear plug cap, no difference.
So I swapped the plugs over still the same, I suspect the coil and have since ordered a s/hand one off the bay
Anything else I could have done, pretty sure the fuel tank pipework is correct
I gotta go out now, so I cant reply
Any help on this matter would be good, thanks
PS, I didn't start the engine this morning so I cant tell you if it was running beforehand, but it was ok the weekend
Thanks , Kev.
Firing on One
Re: Firing on One
The most common fault is fitting the vacuum hose on the bottom outlet spout on the fuel tap (the spout facing the ground) when it should be fitted to the outlet that stick out the side of the fuel tap. The bottom spout is a drain off outlet only,
Re: Firing on One
I'm not sure it's as simple as the vac pipe on the wrong spigot. No vac = no fuel so it wouldn't run...been there done that...
Maybe a trapped or kinked fuel line ?
If it's not running on the rear only it can only be either fuel or electrics.
Quick check on coils is to swap them over & see if the cylinders swap working that will confirm the coil.
If it stays the same it's not the coil...
Re: Firing on One
Well ive defo put the small pipe onto the drain at the bottom so ive got that wrong, oops
will swap over tomorrow and post results.
Still a bit strange how the engine runs at all though
Re: Firing on One
Rear carb float bowl sits higher than front, so it gives dry 1st when fuel flow is slow. Hence will run on 1
Re: Firing on One
Your not the first and won't be the last matekev64 wrote:Well ive defo put the small pipe onto the drain at the bottom so ive got that wrong, oops
Re: Firing on One
yes found the connector at the back of the rock, fitted , runs fine now
and I got a spare coil on its way , another £20
Happy days
Thanks for your help guys
Happy days
Re: Firing on One
At least it was nothing serious, good to know that was all it was
