Rubbers don't stay? ooooerrr
grinner1969
Post by grinner1969 »
:redface :redface :redface There you go, open attack on your fellow friends :lol:
Back to the job, took my tank off, to do bits and bobs, put it back on, but them pesky rubbers that go on the bottom rim don't want to stay in place. I have tried them all ways round but can't get them to stay. I have a feeling that they do work as a kinda shocker against the frame, but if they don't stay in place :?:
Anybody had the same problem with a solution please
Re: Rubbers don't stay? ooooerrr
a little dab of superglue will do the trick mate.... :thumbup:
grinner1969
agentpineapple wrote:a little dab of superglue will do the trick mate.... :thumbup:
That simples hey? Thanks bud :D
I for one has lost at least one rubber tank mount to the abyss that is the V of the engine, the only way to get it back is to strip the top of the bike down.... :(
I also recommend gluing the two rubber strips on the tank, where it meets the front of the seat, these can fall off or split rather easily.
grinner1969
agentpineapple wrote: I also recommend gluing the two rubber strips on the tank, where it meets the front of the seat, these can fall off or split rather easily.
That was my next question about rubbers :D
The one on the left side is fine, the one the right is split and hanging on by a thread, can I get a replacement for these :?:
Also missing an insert rubber from the seat end of the tank (the bolt that runs straight through) can I get one of those anywhere?, have managed to put plastic washers in to space out, however, can feel metal on metal up and down movement, if that make sense, can that be sorted :?:
darkember
Post by darkember »
I would use a dab of clear silicon not as aggressive as super glue :thumbup:
darkember wrote:I would use a dab of clear silicon not as aggressive as super glue :thumbup:
Same here
Man Fat works every time for me.
You dirty bugger !
Or Sikaflex, stays flexible and nowt moves once it's cured :thumbup:
darkember
Post by darkember »
You dirty bugger !
You would prefer KY would'nt you :lol: :lol: :lol:
A dab of exhaust silicone to hold them on for me. The originals just have a bit of double sided tape stuck to the inside of them. They are not cheap to buy new from DS after you add the postage. :eek2
fuel tank rubber edging
grinner1969
thanks guys, useful link that Carl :thumbup:
