dashboard
dashboard
Has anyone changed their clocks on the vtr and if so what did yous get
- agentpineapple
Re: dashboard
jamoi and monkeymatt are two that spring to mind, jamoi went cheap and matt went expensive, now what does that tell you about them....
Re: dashboard
haha well just thinking about seeing if anyone has changed as might be going down this route next year just looking for peoples adviceagentpineapple wrote:jamoi and monkeymatt are two that spring to mind, jamoi went cheap and matt went expensive, now what does that tell you about them....
Re: dashboard
http://bit.ly/1wn7SwJ
Supplement before theyour search query
later clocks site:http://vtr1000.org/
Do you have clocks in mind. Later model storm, OM CBR etc or aftermarket?
Code: Select all
site:
Re: dashboard
Carl was thinking after marker but I do like the look of the later digital vtr clocks but not sure if they would work properly on 98 model storm
Re: dashboard
Folk here have said the later model speedo is harder to read...
Re: dashboard
O right well just need to look at the aftermarket for something nice and easy to fit
Re: dashboard
It's easily done. The biggest issue is the fuel level gauge (not a light). This requires a float in the tank instead of the fuel level sender unit. You also need the later model coolant temperature sender unit (Green plastic bit on thermostat housing). Then there's the wiring block on the dash which is different. No biggie though as you just get the right plug then cut and connect the wires to that.I do like the look of the later digital vtr clocks
The one big advantage with the later model clocks over anything else is that they are made for the bike, therefore the RPM scale is accurate and there are no issues with connecting and accuracy of speedo.
I'm in the boat of not liking the the later clocks speedo scale. It's all positioned wrong for me.
Re: dashboard
I see so would it be easier getting a tank as well from the same bike the clocks are off or that taking it to far ideally would have liked if such is made to buy plug and play now the kosov dashes are nice again relay on the wee pickup magnets positioned on the front wheel
Re: dashboard
You make it sound like there are people who like itcybercarl wrote: I'm in the boat of not liking the the later clocks speedo scale. It's all positioned wrong for me.
Re: dashboard
Found this on fleebay looks nice just emailed the guy ebay item number 331383556701
Re: dashboard
Just got this back from the guy
Hi, this would be as easy as any bike but I think a VTR does not Rev too high? I might be wrong but the revs on this go up quite high? Thanks now is he right with the revs
Re: dashboard
Yes, good luck with finding one though.so would it be easier getting a tank as well from the same bike the clocks are off
As long as you remember the red line is lower your OK. But yeh he's right. It means half the scale is only there for show and not used. A bit like the later speedo we was talking of earlieris he right with the revs
- turbo_billy
Re: dashboard
Looks like the big red light is a shift indicator light. You should be able to set this to an RPM limit of your choice and when you reach that RPM it will come on. Match it to just below the Storms red line and jobs a good one.
The RPMs will still display properly as long as you have the unit calibrated correctly.
Re: dashboard
Thanks guys using the shift light I had thought about that since u can set it might just go with this dash
