Glue for sticking heat sheald
Flatline
Post by Flatline »
So which glue do I use to stick the heat reflective shield to the inside of my bellypan then?
Re: Glue for sticking heat sheald
hi-temp silicone
cheekykev
Post by cheekykev »
Flatline wrote:So which glue do I use to stick the heat reflective shield to the inside of my bellypan then?
Use PuraFlex 40, It's great stuff and wont let go, I used it on my SP where it's well known for melting the bottom panel and it's been fine, just get some plumbers soldering matt, cut it to shape and stick it on with PuraFlex 40, job done, see link below :thumbup:
https://www.roofingsuperstore.co.uk/pro ... oCEPLw_wcB
Like what you do
Do what you like
