Is there a guide to fitting a swingarm brace?
NZSpokes
Post by NZSpokes »
Ive searched and cant find one.
Re: Is there a guide to fitting a swingarm brace?
No guides .
You have all the parts needed .
What you need to do now is .
Remove your swing arm if you don't have a spare .
Remove the hugger mounts and caliper carrier mount from the swing arm.
Clean it up then place the brace on the swing arm have it welded up .
The blade caliper slider bit lines up with the fat bit facing down .
Fit the rear spindle and caliper carrier so that that the slider is level and mark its location then weld that on .
Dress up the welds and paint or powder coat the swing arm .
thedeatons
Post by thedeatons »
My build thread has a pretty good description, and also quite a few pictures. People asked me detailed questions on the install and i tried to answer as best as i could. Lots of information on it here:
http://www.superhawkforum.com/forums/me ... ild-30939/
James
lumpyv
Post by lumpyv »
you will have jamie over there before you know it. he did a bang tidy job on his black one ..
