Engine and exhaust.
TonyW650
Engine and exhaust.
Post by TonyW650 »
Afternoon,
Well Im finally getting around to it, after Storm being sat under a cover for over a year.
Whats the best way to drop the lump out?
Remembering I do still have a bad back!
Ive managed to ease the exhaust header bolts undone, with the aid of some easing oil spray, front fairings off, rads and pipes off.
And do I need any special tools?
Only other question I have is are the exhaust collars front and back the same?
my front one on fubard and was going to make a new one up cut exhaust, slide it on and re weld exhaust as the headers are fine.
Re: Engine and exhaust.
Why not make up some split collars, that would save you having to cut and re-weld the headers and the risk of getting them out of line. I'm pretty sure front and back collars are the same.
Split collars as in this link:-
http://www.ebay.co.uk/itm/Kawasaki-1986 ... 53ee7fb8ab
TonyW650
Post by TonyW650 »
Now thats a idea, cheers for that Chris, Ive got a mate with a lathe and a milling machine.
Its about time I sorted the storm out!
OK Engine out...
What I did was hoist the bike up via the subframe. Rear wheel & swing arm off...Lower the bike back down onto a crate, headers need to be off so it's sitting on the sump only. Put a ratchet strap though the V & around the crate...
Remove Forks, clocks & subframe.
I was stripping the bike right down so the loom is off as well.
Now all ( :lol: :lol: :lol:) you have to do is remove the engine bolts. On the left hand side a the 'castle' nuts which do need a special tool, you can make one out of an old socket or they sell them on the bay or you could remove them with a hammer & drift.
The top one is normally the git to get out...good luck heat & a large hammer are your friends here. Top one goes all the way through as dose the bottom one. Then there are two smaller ones one each side in the middle.
