just got her back together and had first run just a small niggle got a flat spot right at start of throttle. will rev up fine at stand still but when out under load if you go for a handful she bogs down splutters slightly thinks about it then goes off like a scolded cat!!! set carbs up to settings everyone gives on here as in fuel screws and TPS sure its something simple any ideas please?
cheers
Jim
bogging early
Re: bogging early
Keep playing with your fuel mixture screws. Sounds like you may be a little rich. You could try pulling the choke out a tad (very slightly) to see if it improves or not. The choke is technically an enricher so if it gets worse then your running a little rich so turn the fuel screws in a 1/4 -1/2 turn in and try again.
Re: bogging early
Like Carl mentions, use the choke/enricher to find out what direction the problem is
Also, what's your current carb/filter setup
Re: bogging early
cheers guys had a feeling it would be the mixture screws will have a fiddle at weekend carl.
carb/filter are all as standard
Re: bogging early
Over here in the states i think all firestorms are red lol. Looks really good in black and orange!
