regulator/rectifier.
- alanfjones1411
I have had cct's changed to manual,and i was going to change r/r for a mosfet r/r but the mosfet one has two plugs and my r/r that is the original flat one (without the cooling fins) only has one plug with five pins.How does this work?
- Metalmad18
Re: regulator/rectifier.
are there five cables going into the plug? 3 yellow, 1 red 1 green?
Honda VTR 1000F 1997 Black
Arrow Exhausts
Maxton Rear Suspension
Renthal Grips
R&G Bar Ends and protectors
ASV levers
Blackbird Stand
Wanted
Manual CCT's (bought but need to be fitted)
Mosfet Reg/Rec
Arrow Exhausts
Renthal Grips
ASV levers
Blackbird Stand
Wanted
Mosfet Reg/Rec
Hence why the need to rejig the existing loom wires with the different connectors
http://www.vtr1000.org/phpBB3/viewtopic ... 82#p351482
R1/R6 Regulator/Rectifier Swap > http://www.superhawkforum.com/forums/kn ... wap-14380/
- alanfjones1411
Yeh 3 yellow 1red 1 green.How do you tell what order the yellow wires go?I can see in the picture where red and green go.
The yellows can go in any orderalanfjones1411 wrote:Yeh 3 yellow 1red 1 green.How do you tell what order the yellow wires go?I can see in the picture where red and green go.
The three yellow wires come from the stator and are the same - hence the same yellow colour so they can't be mixed up.
- alanfjones1411
