Hi all. My Storm is a '98 with 34,000 miles. No play or problems with the S/A so would I be wasting my time in removing it and regreasing?
Swinging Arm
- Stormin Ben
Do it anyway mate
As they leave the Honda factory they've cut costs by applying the bare minimum of grease.
Remove the rear shock linkages (and while you're at it remove the swing arm as well coz it only adds 5 mins to the job)
Check all the bearings and clean them up and re-assemble with plenty of grease
You'll notice the difference
Ben
Ben
Stripped out the rear end last evening - all nice and lubed so wasn't really necessary but now I know its OK! Didn't remove the bearings to check them as some would need replacing anyway then and seemed pointless as well greased. I'll leave the accumulated oily crud around the area as it keeps water out anyway!
