Where do these go?
VTR Phoenix
Where do these go?
Post by VTR Phoenix »
have been searching filches for what seems like forever but don't know where these parts go. As I got the storm in bits and nothing was labelled up I am a little lost. Can anyone help?
This I believe goes on the front carb sync nipple?
These I know are cable/wire tidies but where do they mount?
The rest I do not have a Jimmy choo
Any help in finding out where these go is greatly appriciated
Ckennedy
Re: Where do these go?
Post by Ckennedy »
I belive your right with the 1st pic.
The 2nd pic where you have no clue o believe are clips that fit under the seat but they normally get removed to make getting the seat on and off easier.
The 3rd pic, look like belly pan brackets which mount around the sump using the sump bolts.
The other bits I'm not to sure on but someone will know more and or correct anything I've said
Sent from my SM-A300FU using Tapatalk
VTR Phoenix
Ckennedy wrote:I belive your right with the 1st pic. I shall fit this tomorrow
The 2nd pic where you have no clue o believe are clips that fit under the seat but they normally get removed to make getting the seat on and off easier. If that's the case I wont worry about those
The 3rd pic, look like belly pan brackets which mount around the sump using the sump bolts. That might make sense as I have two fitted already as per the parts filche I looked at but they didn't seem substantial enough to hold a full size belly pan.
Thanks CK
popkat
Post by popkat »
Picture 2 - cable guides up by headstock I believe (I'll try to remember to look at mine tomorrow)
Picture 3 - doesn't look like a bike part.
Picture 4 - Seat mounting brackets, fit to the seat and hook into subframe at front of pillion seat area.
Picture 5 - aftermarket belly pan/fairing lower brackets
VTR Phoenix
Cheers popkat, do you think I will need the seat brackets?
I know one of the tidys fits under the seat (the larger of the two) and I'm sure the smaller one possibly has the clutch line run through it? but not sure exactly of the mounting points.
The small one fits on the left of the head stock holding the loom and clutch pipe .
The big one holds the loom on the inner rear part of the main frame on the left side
TravisZack
Post by TravisZack »
Edit: Lloydie beat me to it but...
Pic 2 are cable stays. Found some pics from my rebuild:
Little one. Up by the headstock, clutch goes through the grommet.
Big one. Inside the left side of the frame by the back of the rear cam cover.
VTR Phoenix
Lloydie, Travis you two are saints and those pics are perfect, loom is all over the place at the moment so after a few hours lip I'll set to tidying it up.
StuartWags
Post by StuartWags »
The after market belly pan brackets i think are for this type belly panImage
As Ckennedy says, these brackets are under seat brackets,
These brackets definitely look like Powerbronze lower fairing brackets as StuartWags says, although there should be three in total.
You can see where they go in this link where I have posted photos:-
http://www.vtr1000.org/phpBB3/viewtopic ... ts#p380004
VTR Phoenix
Thanks a million guys, you have all been a godsend. All parts now fitted, except the bellypan brackets as will have to mod those but only have the two although I do (as per the filche) have the standard belly pan brackets as well so I'm sure I can sort something as the one I've got has no predrilled fixing points so I think work with what I have.
''Where do these go?''
In the bin if you cant find where they go...Hope that helps.
VTR Phoenix
That will be what's happening with the rest of the parts box I got with it when I'm finished
