K-tech fork springs
vanstub
K-tech fork springs
Post by vanstub »
hi gang have any of you used these at all :?:
Life's too short for plain biscuits :thumbup:
macdee
Re: K-tech fork springs
Post by macdee »
vanstub wrote:hi gang have any of you used these at all :?:
NO
but i did get my springs from Roger Ditchfield
for my weight and cheaper if remember correctly
popkat
Post by popkat »
Yes I have 0.85kg K tech springs in mine, they are drop in using the standard spacers, I have 10wt oil and 140mm air gap, preload set to 25mm, forks dropped 5mm through, you need to drop front as the springs make the bike sit higher at the front (as standard they sag more), might go down another 5mm on mine for the summer.
Yes, I've had some in various front ends, recommended.
Actually, I have a set of springs and cartridges in my Sp2 from them, courtesy of the po.
countrymick
Post by countrymick »
get them rogered...you know you want to :thumbup:
vanstub
Post by vanstub »
NO
thanks didn't realise he just done replacement springs i'll have to email him then
vanstub
Post by vanstub »
countrymick wrote:get them rogered...you know you want to :thumbup:
you're right Mick but its just the hassle of getting them to him :problem:
vanstub
Post by vanstub »
popkat wrote:Yes I have 0.85kg K tech springs in mine, they are drop in using the standard spacers, I have 10wt oil and 140mm air gap, preload set to 25mm, forks dropped 5mm through, you need to drop front as the springs make the bike sit higher at the front (as standard they sag more), might go down another 5mm on mine for the summer.
hi popkat sorry but my bike knowledge is minimal how do you determine what weight of spring to get and just to prove my ignorance how do you set preload and what does it do :confused
Without sounding rude if your knowledge is small should you undertake this sort of task yourself? More from a safety point of view!
carmanbikes
Post by carmanbikes »
Hi, I got some and then took them to Roger to fit, What a difference it made the front end is really good :thumbup:
vanstub
Post by vanstub »
carmanbikes wrote:Hi, I got some and then took them to Roger to fit, What a difference it made the front end is really good :thumbup:
yeah but not as good as your ass end will be with ya new shiny thing :mrgreen:
vanstub
Post by vanstub »
i'll be getting someone to sort it for me just want to get everything together first and know my options :thumbup:
carmanbikes
Hahaha hopefully :thumbup:
As long as the host (or someone local) has a steering stem stand it's do-able on a workshop day- suggest you also trawl the fork rebuild threads and decide what weight of oil you need, and let us know in advance and we'll make sure all the right kit is there.
While you're doing that job it's not much extra work to replace steering stem bearings if it needs doing. Again, forward planning needed as parts of the bearings need to go in a freezer overnight.
tony.mon wrote:As long as the host (or someone local) has a steering stem stand it's do-able on a workshop day- suggest you also trawl the fork rebuild threads and decide what weight of oil you need, and let us know in advance and we'll make sure all the right kit is there.
All the kit at Grainstorm inc the freezer, you'd just need to post the bearings to me in advance...
http://www.vtr1000.org/phpBB3/viewtopic ... 14&t=38611
