Hello fella,
Whats this I hear about you and stick on vinyl race plates? Can you source some? If so, Im after some but Id like some that fit as one piece rather then two seperates - mainly to cover up a scuff on the seat unit!
If possible, whats the SP?
Wayne
Earth to Neilo!
- firestorm996
- Contact:
Wotcha Wayne
Yep I did some for my storm and they worked out really well. All you do is buy a sheet of vinyl (the kind that signmaker shops use for car bodywork decals) cut it to shape then apply. Its not quite as straightforward as that but I don't have enough time to run you through the whole procedure right now. If you get some vinyl I'll give you the whole SP tho m8, it's quite easy, takes a bit of patience but I did front panel, seat panels and seat hump in one evening so its not that bad.
:wink2
:wink2
Firestorm996
'98 VTR in black - road whore - track bitch
