Clutch slave change
Pem Brooke
Clutch slave change
Post by Pem Brooke »
When I parked the 'Storm in November I noticed a drip of fluid from the clutch slave. Sourced a replacement from the forum (thanks Tony) and finally got round to fitting it today. Shame on me for not replacing the fluid before it got to this, but wow, could not believe the crap fluid that came out of the pipe work! Decided to clean out the master and the pipe work and after fitting the new slave, bled the system and now we're road ready.
Lesson to self...change the fluids before they cause damaged! Next are the brake fluids... :thumbup:
Twist it 'til it breaks, then back off half a turn.... :eh:
Re: Clutch slave change
oops that looks ugly indeed :eek2
YUK!!!
ConTRo13R
Post by ConTRo13R »
Check out mine
Pem Brooke
Wow! Even worse than mine....did yours leak too? :?
8O not good.
I agree, regular brake/clutch fluid changes are important due to the fluid being hygroscopic,
ConTRo13R
Post by ConTRo13R »
Pem Brooke wrote:Wow! Even worse than mine....did yours leak too? :?
Nope, no leak but you can see why haha all that gunk will be blocking any leaks like a gasket!
