I was doing about 20 MPH and my firestorm died, i have no electrics, power no ignition light or anything.
I have tried the main 30 amp fuse and that's ok.
I need help big time please.
Mate try and disconect the pos battery terminal and then secure it again. mine does it and that sorts it. if that works your bty is on the way out. hope this helps.
Hey presto yeh ha .
Checked my wiring from battery all the way to front end, under the clocks there is a 3 way block that had popped out, took about 2 1/2 hours.
saved myself a fortune, might just go and buy some bits instead.
