Speed Healer ?????
cheekykev
Speed Healer ?????
Post by cheekykev »
Hi all, has anyone fitted a speed healer to their FireStorm ? If so which is a good one to get, and how easy are they to fit ?
Like what you do
Do what you like
Re: Speed Healer ?????
i just removed one from mine. it was a uk spec bike with KM clocks on it. it was just 4 wires on it. no idea what make it was as the print on it looked like. a number 47 special fried rice..... not sure thats any help to you.. :plainsmile
mik_str
Post by mik_str »
been running one for close to ten years now (or more, can't remember) and never had a problem. Mine was/is a Speedo Healer brand. Just plug and play.
turbo_billy
Post by turbo_billy »
Kev, have one of these fitted to the SP..........
https://www.healtech-electronics.com/products/sh/
http://www.bikersdiscountstore.co.uk/sp ... -pd-18.php
They do one for the Storm. Plug and play. Lets you recalibrate for sprocket changes or simply to dial out errors in the original speedo.
mik_str wrote:been running one for close to ten years now (or more, can't remember) and never had a problem. Mine was/is a Speedo Healer brand. Just plug and play.
Kev, I also have a Speedo Healer V4 and like Micky it's been on the bike for 10yrs plus. As Micky points out "just plug and play". Mine sits under the seat as it needs to be plugged in to the wiring harness connectors in the opaque cover which sits behind the petrol tank. Good instructions on their site too on how to set it up for whatever sprocket sizes you have:-
xeris
Post by xeris »
You might also want to look at this http://shop.12oclocklabs.com/SpeedoDRD/ I have had one installed for 4-5 years and working fine. A little less money than the other.
~ Mark Twain
turbo_billy wrote:Kev, have one of these fitted to the SP..........
Same here, on my SP2.
Dead easy to program as well, and simple to adjust afterwards if you change gearing again.
You can set it up with a car satnav telling you the exact speed you're doing.
