solvol finger ?
RAINMAKER
solvol finger ?
Post by RAINMAKER »
Do you suffer with solvol finger, does your favorite digit ache with rubbing?
then share my moment of enlightenment.
while rubbing away in the garage today I thought there must be an easier way to make it shine :oops: when I spotted a big yellow car sponge just right for washing, so cut it into two inch squares and used it with the old solvol :lol: BLOODY GOOD RESULT.
Give it a try............you know you want too :twisted:
Squiffythewombat
Post by Squiffythewombat »
you wear applying solvo without a cloth/sponge? hows that work?
Squiffy_The_Wombat
Hi nhr22259,
Your sponge idea for using Solvol Autosol works a treat, I actually used the harder type sponge which I think is meant for removing flies that are wielded onto your fairing and screen, but it definetly does make the job a lot easier! many thanks for the tip,
cheers Chris :D :D
