front paddock stands
- essexbloke
Im off to the BMF in a couple of weeks. Sole (main purpose) to find a decent, cheap (ish) front paddock stand.
Which is better though?
a) the type that have "prongs" and lift from the bottom of the fork leg.
b) the type that specifically lift from under the headstock.
Are either better than the other?
I'll need it to lift all 3 bikes i've got. The storm (as you know) has "squared" fork legs, but the others (RD350 & DR600) both have round fork legs. Will this be a problem with "Fork Lifting" stands? Will i need different fittings?
Any advise on this is appreciated.
Hi Essex Bloke,
Mightn't be as relevant as you'd like, but as you say you need to lift a range of machines... I use an NWS Ulti-Pro. It's a sort of external centre stand (remember them?). connical pins go inside swing arm pivot points.
from there it's a simple matter to put a block of wood under sump.
Advantage over paddock stands etc is stability and solidity. No prizes for
"crashing" in the garage!
(Oh, just remembered, you can use stand to lift bike by either front or
rear spindle, as they're hollow-not sure why you'd want to. Just remembered the sales bumf..)
- essexbloke
- Stormin Ben
Personally I'd go for the headstock one.
They usually come with a range of collars to fit different headstocks and I've aways found mine to be pretty secure
The biggest plus for me is that you can work on the forks with it and also as the mudguard on my Blade forks is floating I can twist them to clear the calipers from the wheel. Makes wheel cahnging a 2 minute job -honstly!!
Ben
Ben
- essexbloke
- essexbloke
- Stormin Ben
Ive got a Micron rear stand, and me and my mate bought an extender between us that bolts onto the top of it, he also has a Micron, so we can use the two of them to get the bike off the ground.
It fits into the hole under the headstock and has various pins to match different hole sizes.....problem is it doesn't fit a storm, the way the pin goes into the head stock means the stand hits the fairing below the headlight.
ended up buying one of the stands that has two prongs on each side and the front forks sit ontop of these.
so just a warning about buying the headstock ones....they might not fit unless you are prepared to take the fairing off every time you want to use it.
PS i'm also going down to the BMF. will be staying in Catterick on the thursday night then heading down to sit in the ques for the campsite on friday. pissed friday and sat nights then heading back to Catterick on sunday, home monday.
cheerz
kev
kev
- essexbloke
EBloke
The theory is that they are universal and should fit most fork types, I've no personal experience of them but have seen a few used and they should be ok, might be an idea to take a few measurments and offer them up to the stand when you there it will give you an idea of fit etc.
- essexbloke
- Stormin Ben
I've used two different ones but I'm not sure which make the ones I've tried are (they were both ultra cheap) ones.
I'll measure the angle between the headstock pin and the horizontal arm tomorrow coz that's the important feature but to my mind if the pin is the right size (ie a nice tight fit into the headstock hole (measure that too)) it won't touch the fairing. If its too loose the angle will be wrong and it will touch the fairing
Ben
Ben
You've got me Ben, how do you make the mudguard "floating"? And, doesn't it provide a modicom of lateral support for the forks?
As for the stand, I've got a pronged lifter. You have to prise the prongs apart a little to fit various sizes of bike, but I've used mine on my Storm, ZXR750, RGV250, KR1S, CBR6 etc. The only problem is that you can't mess with the forks, but mine is used for wheel changing.
I agree with Ben on the headstock lifter, it's a good bit of kit. The best way is to buy a Micron rear stand and the front adaptor that fits into the cup holes on the rear stand. This gives you the best of both worlds, but you can on do one end at a time.
Bikes and scorned women don't mix!
