Hi,
Does anyone now if the rear Huggers are the same for all models?
I.E will one from an SP1 or 2 fit the earlier (2000) Firestorm?
Rear Hugger
Rear Hugger
If you think you are right, or if you think you are wrong, you are right!
Re: Rear Hugger
Don't think so mate. The brace on the SP will dictate a different height over the non-braced Storm arm.
- agentpineapple
Re: Rear Hugger
nope, completely different bike, as far as i'm aware, there isn't another bike out there that uses the same hugger.
Re: Rear Hugger
Just brace the sa, then you can use a triumph, r1, Blade or similar one.
