Factory Pro Kit and Ignition Advancer
carmanbikes
Post by carmanbikes »
Hi all, I have been getting prices for a Factory Pro carb kit and they are saying they will do a package deal which will include a Ignition advancer, just wondered had any one gone this root and was it worth it or just to stick with the ti jet kit, Thanks in advance, :thumbup:
Stephan
Re: Factory Pro Kit and Ignition Advancer
Post by Stephan »
You can order dynojet needles and clips from official distributor as spare parts (2x DNO277 and DE0001). Nothing more is needed. I believe it is possible, it was no problem for carb springs and price was ok.
I've spoken to Roger about ignition advancers and his view is they are not worth it. His race maps had an advance in the mid-range but we're retarded higher up so a +2, or whatever, across the whole range isn't the best.
freeridenick wrote: Sat Jan 06, 2018 1:08 pm I've spoken to Roger about ignition advancers and his view is they are not worth it. His race maps had an advance in the mid-range but we're retarded higher up so a +2, or whatever, across the whole range isn't the best.
the race maps? what sorta ignition was he running? something iv never asked him about.
fabiostar wrote: Sat Jan 06, 2018 4:46 pm
He didn't say, except that Geritt ten Kate did them.for him. I didn't make any notes with not expecting to look at this. I reckon he'd provide the info if asked.
Stephan
Post by Stephan »
Ignitech is fine and really easy to install and use, but you can have troubles to get it, not sure about their customer service in UK.
carmanbikes
That's great guys thanks for the input looks like I will just go for the pro jet kit :thumbup:
I found the ignition advancer +4’ stopped the carb farts
lloydie wrote: Sat Jan 06, 2018 10:54 pm I found the ignition advancer +4’ stopped the carb farts
As did I, however it runs hotter and a four-row oil cooler was needed to overcome this.
carmanbikes
The one Factory Pro one is a +2
carmanbikes
tony.mon wrote: Sun Jan 07, 2018 8:57 am
What cooler did you use Tony tia :thumbup:
carmanbikes wrote: Sun Jan 07, 2018 8:52 pm
An SP one, with adaptors and flexible braided stainless hoses made up by Pirtek.
Not cheap, about 100 five years ago, and other coolers are available.
carmanbikes
Thanks Tony
StuartWags
Post by StuartWags »
i have dynojet kit, 4 degree advance and lightened fly wheel... its different to a standard Storm but not sure which bit give the biggest bang for the bucks
Not notices and cooling problems on the track or road. But i have not done city driving in high ambient temps
carmanbikes
Who does the 4 degree advances the factory pro one is 2 degree
