Air box foam inserts
uk13iker
Post by uk13iker »
Does anyone know where I can get the foam inserts in the air box from?mine have perished thanks.
cheekykev
Re: Air box foam inserts
Post by cheekykev »
Hunts Honda dealer in Burnage, Manchester, they're about £2.50 each, see link below
http://www.huntsmotorcycles.co.uk/contact.htm
Strangely enough I've got the feeling I'm going to need a couple myself when I get to that bit, too busy doing other stuff on it at the moment :D
Like what you do
Do what you like
Buy a sheet of off road filter foam and shape it with scissors.
If it's too thick, you can scissor it to half the thickness.
If you cut it to the correct plan size before halving the thickness you end up with two- just the job.
Poke a hole where it fits over the stub with one blade of the scissors and push it into the triangle.
You'll have enough left over to keep you in filters for life!
podman
Post by podman »
I ordered 2 from David Silvers a few weeks back, I think they cost me £1 or something daft like that.
uk13iker
Post by uk13iker »
Thanks for the replies can’t find them on either hunts or David silvers So will just cut some foam to size
podman
Post by podman »
Good stuff, fyi part No attatched, post was more than the filters. Check out the price another lot wanted for the same item! More than a complete air filter x 2!
uk13iker
Post by uk13iker »
Thanks for that podman. You might of got some of the last few as I can’t find anything for that part number.
uk13iker wrote: Tue Feb 20, 2018 4:49 pm Thanks for that podman. You might of got some of the last few as I can’t find anything for that part number.
David Silver are still listing them, I've just looked :)
uk13iker
Post by uk13iker »
Got there in the end I had put the 2 and 5 the wrong way round haha. Ordered thanks
uk13iker wrote: Tue Feb 20, 2018 10:43 pm Got there in the end I had put the 2 and 5 the wrong way round haha. Ordered thanks
At least you got there in the end, that's the main thing :thumbup:
hallie
Post by hallie »
6 quid delivery across the pond. And air filters are 30 quid cheaper than here :P :P
TIP; Never take a sleeping pill and laxative on the same night
http://morrisonbhp.net/
