Temp gauge
geoff996
Temp gauge
Post by geoff996 »
The temperature gauge goes round to the H after a few minutes running but the fan doesn't kick in. Anybody else had this problem
RIDE TO ENJOY
Re: Temp gauge
Perfectly normal - Fan usually only cuts in when it's hot summer, stop start traffic jammed up urban conditions.
Re: Temp gauge
check the fuse for the fan just incase, mine was blown and I only found out one steam started to come out during city riding
Re: Temp gauge
geoff996 wrote: Fri Apr 20, 2018 4:20 pm The temperature gauge goes round to the H after a few minutes running but the fan doesn't kick in. Anybody else had this problem
Put a live direct to the fan to see if it comes on to rule out the fan not working.
Has been known for stones to get in & stop the fan turning...with the bike off, stick a hand in a see if you can flick the fan blades, they should spin with little effort.
As Al said check the fuse...
After that I'd be checking the sender & the thermostat for faults.
Ignor what Wicky said as he didn't seem to have read your post correctly... :roll:
Yes they will run hot in traffic on a really hot day but the gauge wont shoot up to H as you discribe it...
Normal running temp should be just under the half way mark with it edging up if your in a lot of stop start traffic. Fan only normaly kicks in when it's well over 100*.
When I've had them running up on a stand to check the fan kicks in it can take anything up to 10 mins.
Let us know how you get on.
geoff996
Re: Temp gauge
Post by geoff996 »
My concern is not the fan BUT why does the gauge move round to the H very quickly with in 5 minutes of starting up ?
RIDE TO ENJOY
jchesshyre
Re: Temp gauge
Post by jchesshyre »
Thermostat stuck closed, meaning that the coolant isn't flowing through the radiators?
Re: Temp gauge
jchesshyre wrote: Fri Apr 20, 2018 7:22 pm Thermostat stuck closed, meaning that the coolant isn't flowing through the radiators?
or the coolant level has dropped..
geoff996
Re: Temp gauge
Post by geoff996 »
Coolant level Ok thermostat must be stuck hopefully a quick tap or remove and clean
RIDE TO ENJOY
Martinz
Re: Temp gauge
Post by Martinz »
Or you could have what i had. Exactly those systems except i didnt have a tenp guage, just boiling water out of the over flow. Turns out the water pump impellor had snapped = no pumped water.
Take the radiator cap off when idiling and you should see te water flowing round when you snap the throttle
Stratman
Re: Temp gauge
Post by Stratman »
I had the sort of reverse of this issue and it was the sender from the thermostat housing which was to blame - replaced it and the gauge works normally now.
jchesshyre
Re: Temp gauge
These are all viable causes, and because of this, and having spent many hours trying to track down a cooling system problem on my other bike (CB500) a while ago which turned out to be hardened, badly-sealing carburettor heater hoses (enough to let air in as the bike cooled but not enough to let fluid out!), I would highly recommend proceeding methodically, otherwise you may well find yourself going round in circles and never knowing what the issue really is.
The following list (from Haynes - sometimes they are OK!) may be of help, and I would suggest eliminating each cause beyond reasonable doubt before checking the next one:
  • Coolant level low? Check and add coolant.
  • Leak in cooling system? Check cooling system hoses and radiator for leaks and other damage. Repair or replace parts as necessary.*
  • Thermostat sticking open or closed? Check and replace.
  • Faulty cooling system pressure cap? Remove the cap and have it pressure tested.
  • Coolant passages clogged? Have the entire system drained and flushed, then refill with fresh coolant.
  • Water pump defective? Remove the pump and check the components.
  • Clogged radiator fins? Clean them by blowing compressed air through the fins from the back.
  • Cooling fan or fan switch fault?
*and as my experience showed, this means every single hose, in detail!
geoff996
Re: Temp gauge
Post by geoff996 »
Well all sorted I hope replaced complete thermostat housing,replaced coolant,replaced fan and finally just ordered a replacement fan switch. If it still over heat i'm stuffed, so finger crossed
RIDE TO ENJOY
geoff996
Re: Temp gauge
Post by geoff996 »
All sorted after replacing thermostat, fan finally it was the thermostat fan switch replaced it with a Tourmax one :D
RIDE TO ENJOY
jchesshyre
Re: Temp gauge
Glad to hear it!
E.Marquez
Re: Temp gauge
Post by E.Marquez »
fabiostar wrote: Fri Apr 20, 2018 8:10 pm
You get low readings if coolant level has dropped to below the sender
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
