Page 2 of 2
Re: new to 4 stroke v twins heeelllooooo
Posted: Tue May 01, 2018 6:30 am
by tonyhys
oh dear lord yes the ride home I had one eye on the temp gauge a finger on the kill switch and my vizier up all the way so I could hear hir better
Posted: Tue May 01, 2018 11:08 pm
by tonyhys
The magic is back
I cant get over the transformation of a new set of cush drive rubbers has made at low speed, I can actually run at some sensible revs without the fear of getting all crossed up
I know I should move on to the other forums but one last question before I do, Is the back break normally useless or should I swap the pads and if so what for? (I literally would have to stand on the pedal to lock the back up.)
Posted: Tue May 01, 2018 11:18 pm
by Wicky
Contaminated pads? Standard OEM pads should be fine - Not sure why you'd need to lock the back brake. If coming from a IL4 just change down a gear or two before a corner, and as you ease the clutch out the V twiness should cause a rear lock up...
Check disk for wear/contmination and brake system is fully bled with fresh fluid.
Posted: Wed May 02, 2018 3:07 am
by Cadbury64
I agree that any pads should do in the back; I think I have some Goldfren's but I'm not that fussy, I pay a LOT more attention to the front brakes (EBC HH in CBR954 calipers are bliss). My rear brake works perfectly well and will lock up if required, so I'd suggest either contaminated pads (from your oil line leak?) or maybe a stuck piston or caliper. The caliper is on sliding pins and if these are not greased and seized then the brake force can diminish.
I managed to disable my VFR's back brake recently when I got the edge of a pad caught behind the anti-rattle spring.
Posted: Wed May 02, 2018 7:26 am
by tonyhys
Thanks guys, I will pop the pads and check the piston movement
Oh and I don't WANT to lock the wheel like a ten year old on a BMX
Posted: Wed May 02, 2018 3:28 pm
by fatfreddy000
tonyhys wrote: ↑Wed May 02, 2018 7:26 am
Mine also had a terrible rear brake when I purchased it.
The pedal was just solid under my foot and had to be stamped on to do anything.
A set of new pads and cleaning up of the piston solved this with very little effort..
Posted: Tue May 15, 2018 9:00 am
by exTRX850
GDay Ken,
someone parks a BMW SS street style bike nearby at work, tachos goes red at 11,500 !
Wowza.
Posted: Tue May 15, 2018 9:02 am
by exTRX850
Bugger !
Good that you aren't 18 years old & that you knew what to do/not do...
