What is this?
loinstallion
What is this?
Post by loinstallion »
So the bike is getting pulled to bits today. The easy access CCT is a manual but what is this? Cheers.
Re: What is this?
Looks like a Bazza style manual conversion using the OEM body and drilled through to allow fitting of a coach bolt.
loinstallion
Re: What is this?
Wicky wrote:Looks like a Bazza style manual conversion using the OEM body and drilled through to allow fitting of coach bolt.
Mmmmmmm replace then?
Re: What is this?
No need really as it fully functions as a manual tensioner.
loinstallion
Re: What is this?
Wicky wrote:No need really as it fully functions as a manual tensioner.
Nice one cheers.
Re: What is this?
It’s been lockwired in place as well! Does Bazza do them like that or has someone taken it one step further?
Re: What is this?
Kev L wrote: Wed Jul 25, 2018 9:46 am It’s been lockwired in place as well! Does Bazza do them like that or has someone taken it one step further?
No Bazza uses a roll pin on the dome nut. If its been lockwired maybe its been on track, either as a race bike or a paranoid trackdayer...
Check other areas to look for lockwire...sump bolt, callipers ect...
loinstallion
Re: What is this?
Aye it’s everywhere
Re: What is this?
That's the first time I've ever seen a manual CCT lock wired. Not a bad idea though to stop the bolt unwinding should the lock nut come undone.
Seeing as you've found more, Mac it right, it's most likely been raced, or at the very least been prepared for racing,
loinstallion
Re: What is this?
sirch345 wrote:That's the first time I've ever seen a manual CCT lock wired. Not a bad idea though to stop the bolt unwinding should the lock nut come undone.
Aye Chris it’s had a hard paper round but it looks to have been well looked after having now taken it to bits which is good news.
Re: What is this?
and it should have good brakes and suspension mods if it has been used on the track, so its not always a bad thing
Re: What is this?
AMCQ46 wrote: Thu Jul 26, 2018 9:54 am and it should have good brakes and suspension mods if it has been used on the track, so its not always a bad thing
Too true, it may even have had the engine worked on which could mean more bhp,
Re: What is this?
could be a very interesting engine inside :clap: :clap:
