SP1 Strange issue
SP1 Bob
SP1 Strange issue
Post by SP1 Bob »
Folks looking for some clues here.
My Speedo started started giving false readings so I took off the Speedo sensor with the plan to have checked and replace. Cleaned up and put it back on now I have a bike with no power to ignition!!
All I did was take off and then put back on. New battery fitted thinking it might be this and also didn't know how old it was.
All fuses good even swapping 30amp ones over in case ignition was blown and I couldnt quite see it.
Anyone have this happen to them or any clues to what is left to check please.
Thanks in advance
Bob
Re: SP1 Strange issue
Have you shorted out the pins on the diagnostic plug to identify the fault?
It will flash a certain number of times to give you the fault code.
SP1 Bob
Post by SP1 Bob »
What a tit I am....checking all again last night I hadn't put the earth strap back on it had fallen down the back of the footpeg. Doh
:lol: easy enough to do.
I was going to say a dodgy earth, but wanted to get the diagnostic feedback first.
Glad all's well now.
SP1 Bob
Post by SP1 Bob »
All put back together and just out on bike Speedo is doing the same again reading up to 20mph ish and then all over the place dropping to 0 etc. Knackered Speedo sensor I assume?
David Silver offered me a new one at £197 What's that all about I ask.
Any other models have same sensor?
Thanks
SP1 Bob wrote: Wed Sep 26, 2018 6:02 pm All put back together and just out on bike Speedo is doing the same again reading up to 20mph ish and then all over the place dropping to 0 etc. Knackered Speedo sensor I assume?
Thanks
Find the part No... Here...https://www.ronayers.com/oemparts/l/hon ... 0f-a-parts
Then find equivilant here...https://www.bike-parts-honda.com/honda- ... pare_parts ...if there is one...
SP1 Bob
Post by SP1 Bob »
Thanks will give it a bash
Fair to say sounds like Speedo sensor failure aye?
Bob
SP1 Bob
Post by SP1 Bob »
Superb. Many thanks to all for the assistance
