Chain length
Max
Chain length
Post by Max »
Hi All,
Does any body know whether its possible to run 15/44 on the std length chain(102) or do I need to go up to 104
Max
Ians98VTR
Post by Ians98VTR »
yes thats what i run at the moment mate,no problems with chain,bike is so responsive,in all gears now,give it a try :D
Wow! bet that can shift
Hi Ian,
it must be mental with that set up (15/44) do you have a problem keeping the front down, 8O
Ians98VTR
Post by Ians98VTR »
yes at first,took a bit to get used to but it fine now,only did it to try it but love it like that now,goes like a rocket,fuel consumption still ok as well
Max
Post by Max »
I'll try and locate the sprokets next week then. According to the kamware calculator the std gearing gives 169 mph at the line in top which is way to fast for someone my age, 15 44 gives 148 at the line in top which is much more useable in my view.
Ians98VTR
Post by Ians98VTR »
yes mate sounds about right,extra excelleration much more useful than top end speed :D
Ians98VTR
Post by Ians98VTR »
both renthal sprockets,front £15.00 rear £30.00,but is light as a feather,against standard one,got em from demon tweeks
I've got to admit Ian I would'nt mind giving it a try.
cheers Chris. :D
Max
Post by Max »
its got to be tried, sounds like fun :lol:
Max
Post by Max »
Just been looking through the demon tweeks cat and its possible to go 14 46 that would be interesting. it gives 132 at the line in top
Hey Max i've just been looking at the Kamware calculator, how much info did you need to enter to get a result as you did?
Max
Post by Max »
I filled in all the boxes except them that was black. I think that if you know the ratios you dont have to put in the gears though.
Mine looks like
honda firestorm rpm 9500
prim ratio 1.682 teeth crank 44 driven 74
1st 2.733 15 41
2nd 1.813 16 29
3rd 1.429 21 30
4th 1.207 29 35
5th 1.080 25 27
6th 0.962 26 25
final reduction 2.56 drive 16 driven 41
rear tyre dia 24.80 circ 77.91
I just played and if you know either the ratio or gears you only need one
then press calculate button, voila
I got the gears from the manual and measured the back wheel circ and converted to imperial.
Hi Max,
Thanks for that mate, I think I may just have a little play on the Kamware page,
cheers Chris. :D :D
logan7
Post by logan7 »
A blackbird rear sprocket is 44 teeth and same part no as firestorms and demon tweeks has jt sprockets for 19.99 :twisted: i have renthal 15 on front must try this on back. wish me luck :wink:
The force is strong in this one
Ians98VTR
Post by Ians98VTR »
good luck,£30.00 rear is hardened,anodised racing sprocket,weighs nothing,and is worth the cost mate,av a go you wont regret it!! :D :D
