Suday 28th
Moderators: AMCQ46, geodude
firestorm_al
Suday 28th
Post by firestorm_al »
Had an excellent run yesterday. Just over 200 miles.
Only one incident when my bike started to missfire and started to run on only one cylinder just past Glenshee. Eventually traced the fault to a dodgy rear HT lead. The thing fell apart in my hands! I managed to push the lead back together and had no further problems!
MY bike is handleing like a dream at the moment. I had the forks re-sprung earlier this year and I've just fitted a new WP rear shock and new suspension linkage bearings. The other thing I did was to remove the spacer I had in above the rear shock. With the suspension working properly now I prefer it without it! The only other change from stock is the forks raised through the yokes 5mm.
Al.
WayneM
Nice!
Post by WayneM »
Sounds like you had a blast fella. I was building sand castles with my daughter - well actually, the way it went was, I built the sand castle, 15 seconds later my daughter stamped on it !
Well envious of all the bikes that filtered down my traffic queue - bastids!
