Firestorm around town
Guys a little bit of wisdom from you please. I'm new to the Firestorm and new to v-twins, so excuse the ignorance with this question; should the firestorm be a pig in first and second around town?
It feels as if it's going to cut out on me, slow speed roundabouts are a nightmare. The bike is new, about 120 miles on it now.
Any help would be appreciated.
Yes, another Fireblade owner, but fug me she shifts like s**t off the proverbial and handles like a dream (wet)
I've just got a new one and the same thing happened to mine, It kept cutting out whilst ticking over at road junctions, mines now got @ 500miles on it and is getting better, just don't think that they like being ridden slowly........ Oh dear what a shame!!!
I think you may be talking about the infamous VTR fart or hiccup.
I normally get it when blipping the throttle or if sitting at traffic lights or slowing down after engine braking. Every now and again it will cut out. Its got something to do with the carbs but they all do it (some more then others). If it does it alot, Id take it back to the dealer - I have heard of one occurance where the owner did this - the Honda garage gave up trying to fix it and gave the guy a new bike.
Wayne
Wayne
Thanks guys,
I will persevere with it for now, until the first service at least
I’m itching to get out and clock up the miles, but stealing some time in the relative dry is difficult. I don’t mind going out on damp roads, hones the skills (I’m told), but pissing down, forget it
Ride safe and thanks again.
- Dylan Rogers
Hi also new to storm just off B12. This low speed hiccup seems to be a common fault and makes pulling away a problem. When the fart happens just as you are letting in clutch and opening the throttle the bike starts to die so you grab more throttle, the bike recovers finds the rider asking for oodles of gas bites hard raises the front wheel in a massive clutch grinding noise and scares the owner shitless. Take bike to a dealer and find out "oh they all do that" !!!!
What else is in the hidden ccupboard?????????
- blackstorm
Blackstorm, do you run yours at this idle speed? Mine doesn't seem to be as bad as Dylans but I suppose there is still time.
All things said and done, still great fun to ride, just got to get used to it
- firestorm_al
- Site Admin
- Contact:
- Dylan Rogers
Firestorm fart
Completed over 1000mls on storm now and have started to get used to the hiccup. Blipping the throttle is definetly the problem that causes the fuel starvation
, however with a pair of MIG high level race cans fitted how do you keep your little danny's off the noise button!
Will try to up the tick over to 1100.
Very happy with bikes fast cornering after the B12 much happier with the storm despite its little idiosyncrasy. (put dictionary back on shelf!)
Throttle speed
Right, home tonight and in the garage, fiddle time
Thanks for the help guys, ride safe
- firestorm_al
- Site Admin
- Contact:
Re: Throttle speed
You should be able to reach the idle adjuster just by sticking your hand through the frame at the right hand side and turning the knob with your finger tips.pricey wrote:Right, home tonight and in the garage, fiddle time![]()
- blackstorm
Yep.
Mine was constantly stalling when I first got it with tick over at about 800. I dialled it up to 1100 and it will still occasionally stall but not as frequently. Blipping the throttle at tickover makes things worse and if only I was adult enough I would stop doing it, but as above a full Ackropovic race system and no self controlI cant help myself. tut tut childish antisocial etc etc I know, God I know.
smoking guns
Blip away, I can't wait to get my cans, I've not decide which ones yet, I think I've read at least four different makes on this forum now
I will give the new idle speed the full test tomorrow, off to work on the pride and joy
ride safe
ride safe
Carb balance checked
Del
Carb balancing even on a new bike? I've only done 150 miles so far. You would have thought out of the factory they may have set it right in the first place.
