sirch345 wrote:Are you using something different than the standard set speedo, now you have altered the gearing, as if you are it would be interesting to know if fuel consumption is worse or better.
Cheers Chris.
My guess is that the fuel consumption based on the speedo readings will stay the same. However if I get the Sigma fitte I may be in for a shock. Nind you I've been running a +2 rear sprocket for the last 2 years so an extra tooth ain't gonna make much difference
PS What decent weather?
Since I've been
forced to drive the boss' Mazda RX-8 for the last 2.5 weeks I've been praying for rain coz its got too much grip to spin the rear in the dry in anything other than 1st gear. Only had 2 days of serious sideways action, the rest of the time it been dry
Ben
