carnkshaft
Moderator: VTRDark
daz350
carnkshaft
Post by daz350 »
Hi need a crankshaft can be knackered only need the flywheel side
Re: carnkshaft
daz350 wrote: Sat Feb 15, 2020 9:47 am Hi need a crankshaft can be knackered only need the flywheel side
I have one Daz... Not sure what it's worth but the postage will be a bit rich...
Make me an offer.
Re: carnkshaft
If it's to make a mandrel to turn down a flywheel, many Honda's use the same taper and diameters, a trip to the local breaker with your flywheel will see you right.
I have an SP1 crank which will fit, but the postage will be horrendous.
daz350
Re: carnkshaft
Post by daz350 »
Yes that is what it's for.If i can get one a reasonable distance from gloucester will collect one.It's a very big chunk of metal to post
Re: carnkshaft
daz350 wrote: Sat Feb 15, 2020 7:41 pm Yes that is what it's for.If i can get one a reasonable distance from gloucester will collect one.It's a very big chunk of metal to post
IOf you cant find one local... I can always get me grinder out & slim it down a bit for posting :thumbup: ...
