Back to basics
scrumps
Back to basics
Post by scrumps »
Hello!
I am a car qualified engineer BUT live in a top floor flat, no allocated parking so working on side of street...
Is it easy enough to change the plugs on a storm without special tools, a one off plug spanner etc etc I have the seemingly normal problem of it dropping dead at mini roundabouts / traffic lights. Want to increase tickover (it is low) and seems advice is to change plugs as well, any advice very much welcomed.
Re: Back to basics
If you have the toolkit there's a plug tube spanner included. If you don't, you will need a thin wall socket. It's easy enough to do. The front ones a bit fiddly, you're working by feel rather than sight, but not difficult.
Before removing a plug, give the hole a blast of compressed air. You can buy a can designed to clean out pc keyboards and use that if you don't have a compressor to hand.
You don't need to remove the tank to access the rear plug, just undo the front bolts and pivot it up.
Re: Back to basics
Turn the idle up to 1100/1200 revs with the black plastic knurled knob located on the right hand side(as you sit on the bike)
scrumps
Re: Back to basics
Post by scrumps »
Many thanks for the info, idle is much better now and it seems to be smoother to boot!
Re: Back to basics
scrumps wrote: Thu May 27, 2021 6:43 pm Many thanks for the info, idle is much better now and it seems to be smoother to boot!
Well done :thumbup:
