wont rev over 5000 rpm
vxmonaro
Post by vxmonaro »
hi guys my first post here and i have a problem with the vtr not revving past 5000, last time i rode it it was fine but not now, checked timing all good replaced rr and plugs, could it be the pulse generator? hoping someone can help cheers andy, very good forum by the way
mjvw
Re: wont rev over 5000 rpm
Post by mjvw »
Misfire or wont rev above 5000rpm full stop?
Storming About :thumbup:
vxmonaro
Post by vxmonaro »
wont rev bro no misfire
mjvw
Post by mjvw »
Hope you get it sorted take it nothing as been apart or changed ?
Have you seen this thread.
http://www.vtr1000.org/phpBB3/viewtopic ... 3&start=30
When you say you checked the timing, did you have the bike apart before for anything?
vxmonaro
Post by vxmonaro »
hey yes a few mths ago to change ccts and jet kits but was running great up until now
If this happened after you changed the CCTs then you have the rear cylinder timing out 180 degrees.
vxmonaro
Post by vxmonaro »
might have found the problem the carb slides arent opening at all under acceleration
double checked timing all good
