Raise seat height in front
Acke
Post by Acke »
Hello!
I'm somewhat suffering from squished balls from sliding towards the tank at all times.
Tried scooting myself back a bit but as soon as it vibrates or braking I slide all the way forward which isn't very pleasant... :oops:
Is there a smart or easy way to raise the front of the seat by adding another lip to slide the saddle into? :thumbup:
Re: Raise seat height in front
Ger it re upholsterd. Explain what you want re extra padding.
Don't use Pledge on the seat.
Acke
Post by Acke »
MacV2 wrote: Wed May 24, 2023 12:40 pm Ger it re upholsterd. Explain what you want re extra padding.
Re upholstered?
Acke wrote: Wed May 24, 2023 4:24 pm
Re upholstered?
Have it recovered with inserts such as a bump stop (raised section to protect the family jewels from hitting the tank) plus other options in foam selection etc.
I have heard good results from Elsemade:
https://elsemade.com/
Also recommend fitting something like stompgripz to the tank so you can grip the tank with your thighs when braking. It’s a good thing to do for the Handling of the bike as the only forces on the bars are now for control of bike, not support of your weight, and it keeps your Crown Jewels off the tank (until you hit a car!, don’t ask me how I know!)
Empty ya sack before a ride lol .
sisumi
Post by sisumi »
I use a Tribo seat cover at the passenger end - it stopped my kids sliding around. On their site it only shows passenger seats, but there must be something similar for a whole seat out there.
Harveyz
Post by Harveyz »
I had a similar issue as mine has a WP shock which is longer than stock to sit the bike more on its nose - great turn in but you're constantly sliding forward so loads of weight on the bars - fitted eazi-grip pro tank pad - a revelation - you can grip the tank with you knees and they're so grippy when setting up a corner you can stay fixed in place with just the inside of you knee on one leg while braking hard - we'll worth £38
