Testing fuel sender unit
Donut 77
Post by Donut 77 »
Any idea how to test these prior to installation?
TIA
Good job I’m not in a rush…
No longer in the B154-M club.
Re: Testing fuel sender unit
Stick it in. See if it works. If not. Replace.
Simples!
Donut 77
Post by Donut 77 »
Yes, but I’m a way off any power yet and while the tank is still awaiting a de-rust and in bits I need to test this, as there’s some cheap on eBay right now if it’s faulty.
Does it measure the actual level or just sense when fuel is low? I was thinking could the bit with wire be tested in water or even petrol and what readings should I be looking for?
