Hugger
ips
Hugger
Post by ips »
I’m looking for a hugger, ideally one that stretches below the swinging arm to give the suspension linkage some protection.
The only one I can find that looks like it will do the job is from Pyramid Plastics.
I’ve never seen a Storm with one fitted.
Has any one got one fitted, does it do the job. Are there any other makes?
Cheers.
Growing old is mandatory; growing up is optional.
VTRgirl
Post by VTRgirl »
Awwwww, c'mere ips... I'll give you a hug!
ips
Post by ips »
Awww shucks VTRgirl that’s nice. But will you protect my linkage! :lol:
Hi Ips
I've got one, but it doesn't keep the linkage clean :cry:
it does however keep the crap off the rear shocker and engine :lol:
eddvtr1000
Post by eddvtr1000 »
sorry but am i being daft, havent you got the preverbial crap flap?
no hugger just a little piece of plastic that covers all of the rear suspension etc from the ugly stuff that gets thrown from the rear end.
4 cyl = 2ltr , 2 cyl = 1ltr it's all relative.
Stormin Ben
Post by Stormin Ben »
I've got one!
It does a better job of protecting the linkage than not having one
Only have 2 criticisms
1) Coz it goes inside the swing arm it can foul your tyres (depending on gearing) I had a 2 teeth larger rear sprocket so the wheel was closer to the swinger than normal. 010's fitted fine but Rennsports and 208GPa's both fouled it
2) Doesn't really have a chain guard -you have to use the standard VTR one over the top
Ben
No, the crapflap(like that :P ) had to come off cause the hugger comes right down to meet the swingarm.
Ben right though, it does do a better job than the crapflap but the linkages are below the swing arm so there's nothing to stop the crap from off the road flying up and all over it.
RAINMAKER
Post by RAINMAKER »
just a thought but could you remove crap flap and rivit on to bt bottom of the hugger ?
stevieVTR
Post by stevieVTR »
Try NWS (01992 501285). I had one from them on my ZX6 and it extended below the swingarm. It was quite easy to fit and well made. I think they start around £75 - they also do a metallic silver effect which looks really good on silver bikes
.... no more bike, divorce sucks!!!!!!!!!!!!!
pmcq
Post by pmcq »
What about EBay? I got my carbon fibre one on Ebay and am very happy with it! I can check the name on it if you want... It has a flap that goes below the swing arm to stop sh*te going all over the place...
ips
Post by ips »
Thanks for all the feed back.
Ben, do you have to modify the chain guard or does it fit straight on.
Stormin Ben
Fits straight over the hugger with no midification
Ben
