monkey business
emperor
monkey business
Post by emperor »
Ello Peeps :) just got my storm back on the road, whoooo!! after my front cct decided to call it a day booooooooo! ive got some new orange dot honda cct's in at the mo, but, there is no way im gonna just gonna wait for them to go again, so im considering all my options
1.sell the storm (not an option really!)
2.Get some manual cct's and learn how to check them myself and do it every XXXXmiles
as option 1 aint gonna happen, could anyone that has got APE's or any other make installed tell me if they have had any problems with them failing etc... ?? apart from being arsed to check the tention all the time. I dont mind getting my hands dirty once in a while for peace of mind, but, at the same time i dont want to be opening up a shed full of more problems by not using honda parts
ta ta
tim
self note: i will not wuss out and drive a car in winter
I Had the APE tensioners and Max has them.
Personally I can't fault them. Easy to install and other than a little drip of oil working its way past the nut on the rear one no trouble at all. (If I install another pair I would recomend putting a bit of gasket sealer around the locking nut on instalation).
Adustment takes less than ten minutes and only needs doing after several thousand miles.
emperor
Post by emperor »
sounds good to me :) i presume you know when its time to adjust the tensioner as the chain will get a little rattley?
Yep!
and there's no way these puppies will let go on you and try to send your piston into your teeth (or a$$) depending on which one lets go :wink:
ambowen
Post by ambowen »
has any tried the orient express ccts? do they fit?
Max
Post by Max »
I think Bluesman looked at them while back ??
Max
Anonymous
manual cct
Post by Anonymous »
i made my own not that hard to do but u do need a lathe so go see a small freindly machine/engineering shop and if they know wot thier doin shouldnt cost more than 25 bucks a piece
