Is this the same on uk bikes? and if it is has everyone already done it?
> > ----- Original Message -----
> > From: "revolution racing" <roger@...>
> > To: <VTR_List@yahoogroups.com>
> > Sent: Thursday, October 06, 2005 9:32 AM
> > Subject: Re: [VTR_List] Stock header clean up
> > The restrictor in the standard headers is there to
> > assist the pulsing which
> > helps to scoure the front cylinder and to create a
> > turbulence vacumn thus
> > accelerating the gas speed at that point above certain
> > revs. If this is
> > removed the left hand exhaust can will discharge a
> > greater proportion of the
> > gas emmisions.as did the first Akropovic and Two
> > Brothers full exhausts did,
> > until they were modified, to the detriment of the
> > engine performance. Later
> > full systems were designed to overcome this effect by
> > changes in their
> > length, merge angles, tapers and taper length.
> > Honda, Moriwaki, Akropovic and others could have
> > saved themselves
> > millions in R&D if they had only listened to some AU
> > guy and cut away the
> > "excess" to improve power output !!!!
> > Regards
> > Roger
