i am thinking of fitting a scottoiler with the twin feed to the front sprocket. I have read all the previous posts on the subject and cant make my mind up on the positioning. If I just let the oil drip on the chain from the top, the centrifugal force would just fling the oil into the casing, so the nozzle needs to be positioned near the sprocket so that the centrifugal force flings the oil onto the links.
Has anyone fitted a twin feed to the front sprocket?
twin feed scottoiler
V8 on 4 wheels V2 on 2
- Stormin Ben
Have you seen the size of the twin feed unit?
I think you'd really struggle to fit it in the front sprocket area
Also, as you said it, it'd want to feed to the inside of the sprocket but as the front sprocket spins forward you'd need to somehow get it to inject uphill!!
And if you use paqddock stands the rear sprocket's a no-no as well coz the gubbins gets in the way
Best options, obviously IMHO is either a single feed to the front sprocket or bin it and get some chain wax
Ben
Ben
