xxxrated wrote:the VFR/RVF400 both use the same diameter discs and the same calipers as the firestorm
as for the holes i have been told by a few people that the extra holes help to produce more friction on the pad resulting in greater stopping power, that is the theory behind wavy discs.
as for 100g a disc i probably wont noticce it but the fact that the discs are the same price as VTR ones whats the point in going for the heavier option, no point in being narrow minded about things like this
Not being narrow minded, being an enginer i tend to think about how things work rather than jumping on a particular band wagon.
A couple of points, the holes in the disk help clear water when braking, motorcycle brake disks generally are well exposed to the air and cooling is not a serious issue.
Good fluid, HH sintere pads and s/s hoses are all good brake upgrades, i am just not convinced using diskes that are designe for a bike with 30kgs less weight and 50bhp less is an upgrade, moer like downgrade.
Wavy disks are different in finction to the drilled disks.
Besides i am not convinced that the storm needs better brakes othe then the pad,fluid/hoses upgrade, i suppose unless you are doing a lot of trake days.
I am pretty sure you could lock the front wheel up using the standard brakes and on the road you cant use much more power than that.
All in my opinion of courses, which like on any forum means bugger all.
It's here.........
