HELP
alan
HELP
Post by alan »
HI CAN ANYONE HELP WITH MY WIFES VAUXHALL CORSA WENT OUT THIS MORNING CENTRAL LOCKING WONT OPEN CAN NOT OPEN THE DOORS WITH THE KEY MANAGED TO GET IN THROUGH THE BOOT TRIED TO OPEN THE DOORS FROM THE INSIDE AND STILL WOULDNT OPEN .PUT THE KEY IN THE IGNITION AND NO POWER AT ALL I DISCONNECTED THE BATTERY THEN RECONNECTED IT AND THERE WAS NO SPARK ON THE TERMINALS AT ALL .COULD IT BE THE IMMOBILISER I WANT TO DISCONNECT IT IF IT IS THIS BUT AM STRUGGLING TO TRACE IT
HELP HELP PLEASE WOULD BE MUCH APPRECIATED
GOD I HATE CARS!!!!!!!!!!!
ALAN
baz
Post by baz »
Not sure about no electrics but i had a vectra that the remote key used to go out of sink on!!! The keys are on a rolling code so to re-align them you have to get in the car,shut the door, turn on the ignition and while the ignition lights are on press one of the buttons on the key. This will then lock and then un lock the doors. The key is now re-aligned. Don't know if this helps mate.
yossa
Post by yossa »
when u say you have no power do the ignition lights come on
Alan, are you sure there's power in the battery, it would be a good idea to start there :!:
jurgen
Post by jurgen »
I Agree with Sirch. Sounds to me like you've got a flat battery. In the past i've found that if there is an imboliser that the light's still come on but and the car will turn over but not start...or that it won't turn over. All lecky's should still work.
Otherwise could be that your earth terminal has gone. Had that happen to me as well. Could try clipping one end of a jump lead to the negative terminal and the other end to a point on the chasie. If it starts now then you know that you need to put on a new earth strap.
Bit weird that you can't open the door...is it a newish corsa?
Hope this helps.
Jurgs
Jurgs
alan
Post by alan »
THANKS FOR ALL YOUR HELP GUYS I MANAGED TO GET IT GOING STARTED WITH THE BATTERY BUT TONIGHT WHEN SHE CAME HOME IT PLAYED UP AGAIN I THINK ITS A COMBINATION OF THE BATTERY AND IMOBILISER.WHEN I TURNED THE IGNITION ON THERE WAS NO LIGHTS ON THE DASH NO SOUND OF ANYTHING COULDNT EVEN OPEN THE DOORS WITH THE KEY THANKS AGAIN EVERYONE I WILL JUST HAVE TO PLOD ON WITH IT (WHY CANT SHE WALK) HA HA
ALAN
yossa
Post by yossa »
it may be worth getting the altenater tested if u are getting no power
alan
Post by alan »
Will do cheers alan
VTRgirl
Post by VTRgirl »
I had a VP Calais with an immobiliser. I found that it effected the ignition. Husband was a mechanic (well, still a mechanic, just not a husband :? ) & he couldn't figure it out. Ended up ditching the immobiliser & central locking & just going back to the old fashioned key.
VTRgirl wrote:I had a VP Calais
Did it look anything like this VTRgirl :?: :wink:
VTRgirl
Post by VTRgirl »
Very much so, Sirch, although mine was silver top & bottom (believe all the Calais have silver on the bottom). Got it at a gov't auction after losing the lot before. Ex-husband is a Ford fella & we were bidding on some Ford or other. Missed that & he pointed to the Calais & said "how about that one?" Less than five minutes & more than $25,000 later, it was ours...
VTRgirl wrote:Very much so, Sirch, although mine was silver top & bottom (believe all the Calais have silver on the bottom). Got it at a gov't auction after losing the lot before. Ex-husband is a Ford fella & we were bidding on some Ford or other. Missed that & he pointed to the Calais & said "how about that one?" Less than five minutes & more than $25,000 later, it was ours...
I was just wondering what a VP Calais was really, as I'd not heard of them before, so as I came across a pic or two, I thought I'd paste them up :!:
What does the VP stand for :?:
jurgen
Post by jurgen »
Very Posh :lol:
Jurgs
Sharpe1
Post by Sharpe1 »
VP is the model no. As in Cortina you had TC,TD,TE,TF etc. Calais is the luxury level of Commodore.
Larry.
'99 YELLOW
A man goes to the Zoo, but when he arrives there's only a dog.
It was a Shitzu!
Sharpe1 wrote:VP is the model no. As in Cortina you had TC,TD,TE,TF etc. Calais is the luxury level of Commodore.
Thanks for that info Larry,
