Gunk Removal
pmcq
Gunk Removal
Post by pmcq »
Howdy all...
Anyone have any good tips on cleaning the bike - and I am not talking about wax on - wax off type stuff, I'm talking about about removing the black shite that accumulates around the sprocket area - like the sidestand etc. I have tried degreaser and it works well. But it still looks dirty - I have though about investing in a steam cleaner but - have heard these are good but have never tried one. Anyone use one?
Cheers!
RAINMAKER
Post by RAINMAKER »
I got a de-greaser from Hein Gericke, it worked really well, a 5 lite drum.
BUT TOOK OFF COATING FROM SILVER FRAME...........SO USE WITH CAUTION.
Also tried a steam cleaner, but was not really a great help, oh and watch the electrics if you use the steam.
Zer0Zer0
Post by Zer0Zer0 »
Waaaaaaay back in the days when i did my city n guilds..we used JIZER ..
brilliant stuff work it in with a paint brush.." BUT NOW I USE NEW CILLIT BANG"... SPRAY ON WIPE OFF AND THE GREASE IS GONE. oops sorry
advert mode....
I AM THE STRANGE MAN YOUR MOTHER WARNED YOU ABOUT......
Have a sweetie and stop crying........
[Werthers Original...they never get rid of the taste]
grinner
Post by grinner »
Wurth brake and chain cleaner. Nothing like it!
Your subject tittle say's it all :!: :wink:
GUNK degreaser, well that's one of them.
http://www.autoexpress.co.uk/product_te ... asers.html
thumper
Post by thumper »
cheepest and best i have tried so far is parraffin (sp) on with a 1" paint brush rinse with the hose and bobs yer auntie :P
avalible in D.I.Y. stores everywhere :wink:
i have mmy parrafin in one of those pump action dispensers (you know pump like mad and it holds the preasure)
also from DIY stores and garden centres for pennies 8)
just because your breathing doesn't mean your alive
Anonymous
Post by Anonymous »
i tened to favor a mix 50-50 tar and glue remover and jizer spray on leave for 5 mins tickle it with a brush then jet wash it followed by a weak mix of tfr then jet wash followed by ride round block to dry her off
nobby50
Post by nobby50 »
try the nobby treatment...wd40 spray to remove the gunk,then go under the wifes kitchen sink ,and pinch her mr sheen....failing that try elbow grease !!!!!!!!!!!!!!
It might be old, but it still kicks ass !
Sharpe1
Post by Sharpe1 »
Kero in a spray bottle, works a treat!!
Larry.
'99 YELLOW
A man goes to the Zoo, but when he arrives there's only a dog.
It was a Shitzu!
VTRgirl
Post by VTRgirl »
Get a boy to do it :P .
Oh, and I've been told trusty old Mr Sheen is ever so slightly abrasive.
yellafella
Post by yellafella »
Aerosol brake cleaner and a 1" brush works for me then wash off.
monomaster
Post by monomaster »
I agree with Sharpe1... Kero & a sponge/brush, will remove road grime/tar & grease without effecting things like the o-rings in your chain, gaskets & seals etc, like degreaser will do.
After you have given the bike a going over with kero, start again with normal soapy water to remove anthing the kero didn't take off.
Kero is about a 1/10 the cost of de-greaser too... :wink:
Happiness is a 200kph mono past a Catholic Schoolgirl excursion
jurgen
Post by jurgen »
always put faith in my trusted can of WD40, other wise parrafin. Dad uses Muck off seems to work but leaves a white film after so worth going over with soap and water afterwards
Jurgs
stu9000
parafin holds water
Post by stu9000 »
I was chatting to my neighbour about cleaning chains etc. I used parafin last time and it worked a treat but I found a few tight spots developing afterwards. Easily sorted with a liberal lube but he said parafin absorbs water and that white spirit is better.
red is the fastest colour;)
