FRONT BRAKE MASTER CYLINDER HELP AGAIN
alan
Post by alan »
I just need some advice on brake master cylinder i have found a cylinder which i would like but it has no brake swith attached is it just a case of mounting mine to it i have never taken one apart so am not sure its a brembo one off a ducati
thanks Alan
Stormin Ben
Post by Stormin Ben »
You might be able to do that
Failing that you can get a banjo bolt with a pressure switch in that will be perfect
But its not a very good one!
alan
master cylinder
Post by alan »
Cheers Ben
im just wanting to upgrade and having trouble finding sp1 cylinder or 929 i have 929 complete front end and am watching loads of cylinders on ebay do you know if the k3/k4 gsxr is a 19mm bore.
So i should be okay with a pressure switch you say, could i also have radial brake master and clutch cylinders
thanks Alan
