Its easy
just changed the temp gauge one on mine while its in bits.
You have to take the front fairing off complete, 4 bolts, two horrible plastic screw things under the fairing just at the back of the rads(which I threw away a long time ago and now use tie wraps). Disconnect the headlight,side light and indicators at thier plugs and pull the fairing off.
The instrument panel is held on with 3 screws, undo these to lift the instrument panel clear and you can see the bulb housings. Never checked what type of bulb they are but they are small bayonet type fitting ones.
Hope that helps
