Jack under the engine will be fine (NB use a bit of wood to avoid damage to the sump)jpickup wrote: I've got a rear paddock stand but obviously would need to support the front. Wooden blocks under the engine? Something more substantial?
Rope from the roof of the garage? (it is a rented garage away from where I live so no major mods to the garage allowed!)
AS LONG AS YOU DON'T REMOVE THE REAR WHEEL
The weight of it keeps it nice and steady (found that out the hard way!)
Top tip, loosen the pinch bolts before you take ALL the weight off the front
