Gear lever Posistion.....
Buggs
Post by Buggs »
Hi, had the storm for about 3 months now and love it. However now that i have started to settle in was wondering if it is possible to change the angle of the gear leaver. Mine is just a little to high and could do with coming down a touch. If possible can someone post some instructions on how to do this.... Many Thanks
Fireman on a Storm
Post by Fireman on a Storm »
Look at the rod between the lever and gear box. Undo the lock nut at each end , one left handed and one right handed thread. Then turn the rod and the lever will go up ab down.
Buggs
Post by Buggs »
Easy When you know how and took less than 10 mins... Cheers mate :D :D :D
Fireman on a Storm
You may find dropping the lever helps with the 1st 2nd gear change!
