Fitting braided hoses
Rincewind
Post by Rincewind »
any tips for fiiting braided hoses??
have a rear one arrived from ebay (£9.99 bargin :wink: )
just don't want to blunder in..... :?
Never argue with an idiot, they will drag you down to their level and beat you with experience.
Badger
Post by Badger »
Keep the brake fluid away from any paintwork, if you do spill/splash some, wash/swill it off straight away with water.
Alan
Stormin Ben
Post by Stormin Ben »
My top top top tip is to remove the caliper and pump the piston almost all the way out first.
This leaves you with a caliper full of fluid so that when you attach the new hoses you can push the piston back in and it forces fluid along the hose and UP to the resevoir.
Works with both front AND rear brakes and means you have a firm lever straight away with no need for 2 hours of fruitless pumping on the lever followed by an email saying 'HELP!!'
If the fluid is dirty you can then change it in the usual way
But its not a very good one!
Rincewind
Post by Rincewind »
when i remove the banjo's on the original hose,is brake fluid liable to come flooding out or just trickle???
Stormin Ben
Undo the top/ uppermost one first
Then tip it into a suitable container
Then undo the other one
In any case it'll be a trickle not a gush (unless you're pressurising the system eg by leaning on the brake pedal! :P ) so a bit of rag underneath will be fine
feef
Post by feef »
I'll be doing a full set of hoses on the 'storm this weekend...
a
FJR1300
YZF1000 Thunderace
VTR1000 Firestorm
FZR400
DR350S
stu9000
Post by stu9000 »
red is the fastest colour;)
Rincewind
Post by Rincewind »
cheers stu
need a double bango bolt for the top then....
will do the rear shortly :)
