Perl programmers?
Perl programmers?
As nobody has used this part of the forum yet, here's a question: I am trying to use the ParseExcel function in a web page but I cannot get the data from the spreadsheet. I am not getting error messages, but nothing appear.
Any idea?
Any idea?
- firestorm996
- Contact:
I haven't used Perl myself, but certain problems and techniques are common throughout different languages.
Try to find another function which can be used to verify whether any data is being returned or not. There is probably a .Recordcount equivalent, or maybe a way to dump the returned data to screen.
If Perl uses an ODBC connection to the excel spreadsheet you could use Access to link it as a table, via the same ODBC connection. That way you can verify that ODBC is configured and running correctly.
Firestorm996
'98 VTR in black - road whore - track bitch
- firestorm996
- Contact:
Well Perl probably returns data as a recordset (literally a set of records!) which will probably have properties, just as a file has properties in windows. If you can print this value to screen it will help you to determine whether data is being retrieved or not.
ODBC is Open DataBase Connection, a universal standard in data transfer between one system and another. But it sounds like you're not using that here, so I'll shut up about it.
Btw m8, do you still want to have a quick shufty at my site and see if it can be easily made mac/netscrape compatible?
Firestorm996
That's exactly the problem: no data output and no error messages. Starting to p*ssing me off...firestorm996 wrote:Well Perl probably returns data as a recordset (literally a set of records!) which will probably have properties, just as a file has properties in windows. If you can print this value to screen it will help you to determine whether data is being retrieved or not.
Could do, but I make no promises. Considering the amount of JS and CSS you have used, it might be impossible to modify without removing some functionality. I'll have a go anyway, no prob.firestorm996 wrote:Btw m8, do you still want to have a quick shufty at my site and see if it can be easily made mac/netscrape compatible?
- firestorm_al
- Site Admin
- Contact:
Does your excel file have more than one worksheet??
http://search.cpan.org/dist/Spreadsheet ... seExcel.pm
- firestorm_al
- Site Admin
- Contact:
Try -# select worksheet number 1 (you can also select a worksheet by name)
my $Sheet = $Book->Worksheets(1);
$Sheet = $Book->{Worksheet}[1];
Neil, I just ran your style sheet through TopStyle's style checker function and it's come up with a list of possible errors and compatibility problems as long as my arm!
- firestorm996
- Contact:
Global symbol "$Sheet" requires explicit package name at ..."firestorm_al wrote: Try -
*However*, I run the script from the command prompt after some more tweaking and finally got some results. Now I just need to find out why the html code is not showing the output ...
- firestorm_al
- Site Admin
- Contact:
my $Excel = new Spreadsheet::ParseExcel;Lucazade wrote:Global symbol "$Sheet" requires explicit package name at ..."firestorm_al wrote: Try -
my $Book = $Excel->Parse('Excel/ExcelFile.xls');
my($Sheet);
